Troubleshoot differences between acquisition and attribution reports
Acquisition and conversion attribution reports use different methods to show how visitors reach your website and contribute to conversions.
Differences between reports can be expected, but missing visits, unexpected traffic sources or conversion discrepancies may indicate tracking or configuration issues. Use this guide to identify possible causes and find the relevant troubleshooting instructions.
Tracking and reporting setup
Before troubleshooting acquisition or conversion attribution discrepancies, check your tracking and reporting setup. These initial checks can help identify configuration issues that affect how Matomo records visits and reports traffic sources.
- Confirm that your tracking code or integration uses the correct Matomo URL and site ID.
- Review your website’s consent settings, tracking exclusions and bot filtering.
- Verify the selected website, date range, timezone and active segments.
- If visits are recorded but missing from aggregated reports, check whether report processing is up to date.
- For broader tracking problems, see Addressing unexpected data discrepancies.
Visits missing from acquisition reports
First, determine whether visits are missing entirely or recorded under another acquisition channel. Check whether missing visits appear in Visitors > Visits Log.
- Missing from all reports: Check your tracking configuration, consent settings and exclusions.
- Present in the Visits Log but missing from acquisition reports: Verify the reporting period, segments and report processing.
- Recorded under an unexpected channel: Check whether campaign parameters or referrer information affected how the visit was classified.
Direct Entry traffic is higher than expected
Visits without recognised campaign information or a usable external referrer may be classified as Direct Entry.
- Compare acquisition channels: Check whether Direct Entry increased while traffic from other sources decreased. If total visits remain relatively stable, this may indicate a change in how traffic sources are being recorded or classified.
- Review traffic trends and website changes: If it coincides with recent changes to your website, redirects, consent banner, or campaign URLs, that may affect the referrer information available to Matomo.
- Check browsers and devices: Compare Direct Entry traffic across browsers and device types. An unusually high proportion from particular browsers or mobile devices may indicate differences in referrer handling, traffic from mobile applications or browser privacy restrictions. If the increase is concentrated in certain browsers, see Search and referral traffic decreasing while Direct Entry increases in specific browsers.
- For more troubleshooting, see Referrer links not showing.
Traffic attributed to an unexpected website or channel
Matomo classifies visits using the available campaign and referrer information. If no referrer information is available, the visit may be classified as Direct Entry instead.
- Campaign tracking: If visits are missing from the campaigns report, confirm that your links contain supported campaign parameters with a campaign name. If your website uses custom campaign parameters, verify that Matomo is configured to recognise them.
- Campaign parameters: If a URL contains both
mtm_andutm_parameters, or duplicate parameters, check which values Matomo records. - Search Engines: If search traffic appears under Websites or Direct Entry, check whether Matomo receives usable referrer information and recognises the search engine.
- AI Assistants: If traffic from an AI assistant appears under a different channel, confirm whether Matomo recognises the AI tool and receives the information needed to identify it. Campaign parameters or another referrer may affect which acquisition channel takes precedence.
- Referring websites: If a visit appears under an unexpected website, check whether redirects, intermediary websites or missing referrer information affected the recorded source. See Referring websites missing from the acquisition report.
Note: Visits recorded before the AI Assistants channel was introduced (Matomo 5.5.0, October 2025) are not automatically reclassified. So, historical visits from AI Assistants may still appear under another previously assigned acquisition channel.
Acquisition traffic unexpectedly increased or decreased
Sudden changes may reflect genuine traffic patterns or changes to tracking and attribution.
- Traffic trends: Compare the affected period with an earlier period using the same website, date range length, segments and reporting conditions. When analysing data, consider seasonal patterns, changes in campaign activity, and tracking or website changes.
- Total visits: Check whether overall visits increased or decreased, or whether visits shifted between acquisition channels while total traffic remained stable.
If total visits change significantly, investigate both actual traffic changes and potential tracking issues. If total visits remain stable but acquisition channel totals shift, check campaign parameters and referrer classification.
Attribution and Ecommerce reports show different results
Matomo’s default conversion attribution uses Last Non-Direct attribution, so the source credited for a conversion may differ from the acquisition source of the visit in which it occurred. Ecommerce and conversion attribution reports may show different channel totals because they assign conversion credit differently.
- Reporting scope: Confirm that the metrics, segments and reporting periods are comparable as this can affect comparisons.
- Attribution method: Check whether you are comparing standard Goal or Ecommerce reports with Multi-Channel Conversion Attribution reports. Standard reports use Matomo’s default attribution method. If using Multi-Channel Attribution, check the selected attribution model and lookback period, as these settings affect how conversion credit is distributed.
A conversion attributed to an unexpected channel
A conversion may be credited to an earlier campaign or external referrer rather than the source of the converting visit. For example, a visitor may first arrive through a campaign, return directly and then complete a purchase.
- Converting visit: Identify the traffic source of the visit in which the conversion occurred and compare it with the source credited in the conversion report. Determine if the visitor previously arrived through a campaign or external referrer that may have been retained for conversion attribution.
- Reporting method: Check whether you are viewing standard Goal, Ecommerce reports or Multi-Channel Conversion Attribution reports, which support different attribution models. See enabling the Multi Channel Conversion Attribution for a goal or ecommerce order.
Understanding how Matomo identifies acquisition sources and assigns conversion credit can help you interpret reporting differences and troubleshoot unexpected results. For a detailed explanation of channel classification, attribution models and how conversions are credited to earlier visits, see How Matomo attributes traffic sources and conversion.
