How do I enable the Multi Channel Conversion Attribution for a goal or ecommerce order
Cloud On-Premise
When you create or edit a goal, you can enable or disable this feature. Look for the Multi Channel Conversion Attribution checkbox and make sure it is enabled before creating or updating your goal.
If your website or mobile app has the ecommerce feature enabled, the attribution report for ecommerce orders will be available automatically.
