Complianz – GDPR/CCPA Cookie Consent is a WordPress plugin that supports third party blocking, auto-detection/configuration of plugins and handles consent requirements for different countries based on visitor geolocation. The consent manager includes a step-by-step setup wizard that makes configuration quick and easy and it offers built-in support for Matomo and Matomo Tag Manager (MTM). The Tag Manager method is covered in a separate guide.
This guide focuses on three integration methods using Matomo.
  1. Consent-based Tracking: For websites targeting users in countries that require prior consent for use of cookies and similar technologies for analytics and marketing (for example, most or EU and EEA countries), enable cookieless or cookie-based Matomo tracking only after obtaining visitor consent.
  2. Opt-out Tracking for CNIL Exemption: For organisations relying on the CNIL consent exemption for website analytics, limited tracking is permitted, provided that conditions of exemption are strictly met and users are offered a clear opt-out mechanism. CNIL exemption is strict and if any conditions of the CNIL exemption are not met, consent is also required.
  3. Adaptive Tracking: For websites operating outside the EU/UK/EEA, in countries where prior consent is either not required or only required when the analytics processes personal data, you can enable cookie-based tracking with consent and fallback to cookieless tracking if consent is not given (unless the visitor opts out of all tracking).
Before you start
Install the Matomo plugin
Matomo is compatible with the Connect Matomo plugin and Matomo for WordPress plugin.
  1. Open WordPress to install and activate the preferred Matomo plugin.
  2. For the Connect Matomo (WP-Matomo) plugin:
    • Click on the plugin’s Settings and go to the Enable Tracking tab.
    • From the Add tracking code drop-down, choose Disabled.
    • Save the changes.
  3. For the Matomo for WordPress plugin:
    • Click on the Matomo Analytics menu > Settings.
    • For the Tracking mode, choose Disabled.
    • Save the changes.
  1. Open WordPress > Plugins > Add Plugin > search for Complianz and install; OR
  2. Download the Complianz – GDPR/CCPA Cookie Consent plugin.
  3. Open WordPress > Plugins > Add Plugin > Upload Plugin and select the plugin you downloaded from WordPress.
  4. Once installed, click Activate.
The tracking configuration for each consent method is described below.
  1. Once the Complianz GDPR/CCPA Cookie Consent plugin is installed, navigate to WordPress > Plugins > Installed Plugins.
  2. Ensure the Complianz plugin is activated and click Settings.
  3. From the Complianz Dashboard, open the Wizard tab (or click the Continue Wizard button) to go through the configuration steps.
  4. Follow each step and configure according to your privacy laws and requirements.
  5. In the section, Consent > Statistics, select the following options:
    • Do you compile statistics of this website? – choose Yes, with Matomo.
    • Do you want to use cookieless tracking with Matomo? – choose No. This prevents any tracking before consent is granted.
      integrate complianz with matomo
  6. Continue to the next step, Statistics Configuration and select the following option:
    • Do you want Complianz to add Matomo to your website? – choose Yes.
    • Provide your Matomo instance URL and site ID (for Matomo Cloud or On-Premise). If you are using the Matomo for WordPress plugin, then the URL for your Matomo installation will be: your-domain.com/wp-content/plugins/matomo/app
      configure complianz for matomo
  7. Continue through the wizard to the Cookie descriptions and Service descriptions steps, where you should see auto-configured entries for Matomo.
Remove/disable Matomo tracking
Remove or disable any existing Matomo tracking code from your WordPress site.
  1. If you manually added the tracking code to your WordPress site, it must be removed.
  2. If you are using the Matomo for WordPress plugin or the WP-Matomo (Connect Matomo) plugin, go to Installed Plugins and open the plugin settings.
  3. For the Enable Tracking option, ensure tracking is disabled.
  4. Save your settings.
  5. Do not deactivate the Matomo plugin.
Validate the integration
  1. To simulate different locations, use a VPN during testing.
  2. Open your website and use the CMP widget to decline tracking consent.
  3. In your Matomo instance, select the Visits in Real-time report, and check that no tracking requests are sent.
  4. Next, grant consent and verify that tracking starts in your Matomo instance.
  5. If using cookie-based tracking, open the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were set.
  6. Revoke consent and confirm the Matomo tracking cookies are deleted from the browser.
  7. Perform some test actions and check your activity was not recorded in the Visits in Real-time report.
  1. Your website targets visitors in countries where CNIL or very similar exemption exists (e.g., France, Spain, Italy), or you have an establishment in such countries:
    • Configure your CMP to either load Matomo Analytics cookies and start tracking without prior consent, or
    • Re-categorise the Matomo cookies as Essential/Necessary.
    • The CMP banner must clearly inform users about the use of consent exempt website analytics tracking and include a visible and easily accessible opt-out mechanism (e.g. a link to your privacy policy with an opt-out checkbox).
  2. If your website serves a broader audience that targets visitors from countries that require prior consent for cookie based or cookieless website analytics (e.g. most of EU countries):
    • Consider splitting your banner configuration if the CMP supports region-specific geotargeting and consent rules.
  3. Follow the steps in this guide, How to include a web analytics opt-out feature on your site to add the embedded Matomo opt-out form to your website. The form includes all required JavaScript to allow users to opt-out of tracking.
  4. Alternatively, you can create a custom opt-out form using HTML and JavaScript, as explained in this developer guide.
  1. Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
  2. Select to opt-out of tracking.
  3. Open the browser’s developer tools and view the Application or Storage > Cookies tab to verify that the mtm_consent_removed cookie is set.
  4. Perform test actions on your website and view the Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
  5. Change the settings to opt back in and resume tracking.
  6. Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
  • are not legally required (but you want to minimise the data you collect),
  • are not required for pseudonymised non-sensitive personal data or
  • are only required if certain personal data is processed.
  1. Once the Complianz GDPR/CCPA Cookie Consent plugin is installed, a wizard may appear to take you through configuration steps or you can navigate to WordPress > Plugins > Installed Plugins.
    • Do you want to use cookieless tracking with Matomo? – choose Yes. This allows cookieless tracking before cookie consent is granted.
      configure complianz for cookieless tracking in matomo
    • Provide your Matomo instance URL and site ID (for Matomo Cloud or On-Premise). If you are using the Matomo for WordPress plugin, then the URL for your Matomo installation will be: your-domain.com/wp-content/plugins/matomo/app.
  2. Open your website and use the CMP widget to decline cookie consent.
  3. Use the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were not set.
  4. In the Visits in Real-time report, check that tracking requests are still sent.
  5. Next, grant / revoke consent and confirm cookies were set / removed as expected.
Previous FAQ: How to integrate Didomi CMP with Matomo
