Klaro Cloud CMP integration with Matomo can be implemented using the Matomo JavaScript tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide. This guide focuses on three integration methods using the Matomo tracking code.
  1. Consent-based Tracking: For websites targeting users in countries that require prior consent for use of cookies and similar technologies for analytics and marketing (for example, most or EU and EEA countries), enable cookieless or cookie-based Matomo tracking only after obtaining visitor consent.
  2. Opt-out Tracking for CNIL Exemption: For organisations relying on the CNIL consent exemption for website analytics, limited tracking is permitted, provided that conditions of exemption are strictly met and users are offered a clear opt-out mechanism. CNIL exemption is strict and if any conditions of the CNIL exemption are not met, consent is also required.
  3. Adaptive Tracking: For websites operating outside the EU/UK/EEA, in countries where prior consent is either not required or only required when the analytics processes personal data, you can enable cookie-based tracking with consent and fallback to cookieless tracking if consent is not given (unless the visitor opts out of all tracking).
Before you start
Set up Klaro CMP
  1. Create your Klaro Cloud account.
  2. Complete the necessary steps to configure your Privacy Manager and cookie banner in line with the consent method used and the legal requirements that apply to your website.
  3. In your Klaro dashboard, you will need to add the Matomo service. Go to the Configuration tab > Default Config (or choose a custom one if required).
  4. In the Add a service field, type Matomo and select it to add the service.
  5. Click on the Matomo service to configure the settings.
  6. Select Performance Optimization as the Service Purpose.
  7. Set Service Default State to On.
    Klaro Cloud config for matomo
  8. Add three cookies with the definition entered as a regular expression:
    • cookie1: /^pk.*$/
    • cookie2: /^mtm.*$/
    • cookie3: /^MATOMO.*$/
  9. Save the service.
  10. Follow the Klaro CMP instructions to add the consent manager script directly to your website’s code. The script must be placed as the first element inside the <head> tag on every webpage you want to track.
  1. If you do not have the tracking code installed yet, go to Matomo > Administration Settings Cog Icon > Websites > Tracking Code and select the website you want to track.
  2. Copy the tracking code shown in the code box and paste into a text editor.
  3. Insert the line _paq.push(['requireConsent']); before _paq.push(['trackPageView']).
  4. Paste the modified tracking code inside the <head> tag on all the website pages you are tracking.
  5. If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
  _paq.push(['trackPageView']);
  (function() {
    var u="//matomo/";
</script>
<!-- End Matomo Code -->
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script inside the <head> tag on all website pages that contain the Matomo tracking code.
<script>
    function KlaroWatcher() {};
    KlaroWatcher.prototype.update = function(obj, name, data) {
      if (data !== 'undefined' && data.hasOwnProperty('matomo')) {
        if (data.matomo) {
        } else {
    window.kw = new KlaroWatcher();
    var waitForTrackerCount = 0;
      if (typeof _paq === 'undefined' || typeof klaro === 'undefined') {
          waitForTrackerCount++;
          return;
      } else {
        klaro.getManager().watch(kw);
    document.addEventListener('DOMContentLoaded', matomoWaitForTracker());
</script>
Validate the integration
  • Open your website and use the CMP widget to decline tracking consent.
  • In your Matomo instance, select the Visitors > Real-time report, and check that no tracking requests are sent.
  • Next, grant consent and verify that tracking starts in your Matomo instance.
  • If using cookie-based tracking, open the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were set.
  • Reset your consent and decline tracking consent.
  • Perform some test actions and check your activity was not recorded in the Real-time report.
The French supervisory authority, the Commission nationale de l’informatique et des libertés (CNIL) allows specific configuration of Matomo Analytics to be used without prior consent, provided that strict conditions are met. This is commonly referred to as CNIL consent exemption for audience measurement tools.
Organisations relying on the CNIL consent exemption can track website visitors by default provided that all exemption conditions are met:
  • The data is collected only for audience measurement their visitors are informed about and can object to tracking via an opt-out mechanism;
  • The cookies or other tracking tools used solely for audience analytics;
  • The tracking meets required time limits and produces specific aggregated data sets; and
  • The trackers are not used for identification, profiling, or cross-site tracking of visitors.
Refer to the CNIL consent exemption for Matomo Analytics Configuration Guide (English version) or (French version).
  1. Your website targets visitors in countries where CNIL or very similar exemption exists (e.g., France, Spain, Italy), or you have an establishment in such countries:
    • Configure your CMP to start tracking without prior consent. In the Klaro config.js file, you can set optOut: true and Klaro loads the service before consent is given.
    • The CMP banner must clearly inform users about the use of consent exempt website analytics tracking and include a visible and easily accessible opt-out mechanism (e.g. a link to your privacy policy with an opt-out checkbox).
  2. If your website serves a broader audience that targets visitors from countries that require prior consent for cookie based or cookieless website analytics (e.g. most of EU countries):
    • Consider splitting your banner configuration if the CMP supports region-specific geotargeting and consent rules.
  3. Follow the steps in this guide, How to include a web analytics opt-out feature on your site to add the embedded Matomo opt-out form to your website. The form includes all required JavaScript to allow users to opt-out of tracking.
  4. Alternatively, you can create a custom opt-out form using HTML and JavaScript, as explained in this developer guide.
  • Perform test actions on your website and view the Visitors > Real-time report to verify tracking requests are sent to Matomo.
  • Select to opt-out of tracking.
  • Open the browser’s developer tools and view the Application or Storage > Cookies tab to verify that the mtm_consent_removed cookie is set.
  • Perform test actions on your website and view Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
  • Change the settings to opt back in and resume tracking.
  • Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
  • are not legally required (but you want to minimise the data you collect),
  • are not required for pseudonymised non-sensitive personal data or
  • are only required if certain personal data is processed.
  3. Insert the line _paq.push(['requireCookieConsent']); before _paq.push(['trackPageView']).
<!-- Matomo -->
<script>
  (function() {
    var u="//matomo/";
</script>
The following script listens for consent updates and enables/removes cookies when cookie consent is granted/denied. Add the consent handling script inside the <head> tag on all website pages that contain the Matomo tracking code.
<script>
        if (data.matomo) {
        } else {
          _paq.push(['deleteCookies']);
          return;
      } else {
</script>
  • Open your website and use the CMP widget to decline cookie consent.
  • Use the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were not set.
  • In the Visitors > Real-time report, check that tracking requests are still sent.
  • Next, grant / revoke consent and confirm cookies were set / removed as expected.
Previous FAQ: How to integrate Tarte au Citron CMP with Matomo
