Create and manage websites
Matomo can be used to track an unlimited number of websites. Matomo can track pages on multiple domains and subdomains. Most users track from 1 to 10 websites, but some Matomo servers track more than 10,000 websites!
Add a Website
You must be logged in to Matomo as the Superuser to add a new Website. Click on Administration > Websites > Manage. This page is used to create, update and delete websites.
Click on Add a new website to create a new site in Matomo. The website form shows all the options you can specify:
These are the attributes that you can specify for each website:
- Name: the website’s name
- Alias URLs: domains and subdomains that are tracked in this website. This will ensure that tracked domains don’t appear in the Referrer report.
- Excluded IPs: a list of IPs, or IP ranges (132.4.3.* or 143.2..) to be excluded from being tracked on all websites.
- Excluded Parameters: URL query parameters that should be excluded from URLs, for example session parameters. This will ensure your Behaviour > Pages reports stay clean and easy to analyse.
- Time zone: each website will report data in its given time zone. If you update the website time zone, only the reports going forward will be affected.
- Currency: the currency symbol will be displayed next to revenue in your goals.
- Ecommerce: if your website is an Ecommerce store you can enable the Ecommerce reports
Tracking data anonymisation settings
You can choose whether this site uses the global anonymisation settings or its own configuration.
- System settings applies the Matomo-wide anonymisation rules defined under admin settings in Privacy > Anonymize Data.
- Custom site settings overrides the global configuration and lets you define anonymisation options specifically for this site.
Update and Delete Websites
- Go to Administration
> Websites > Manage.
- To update a website, click the Edit icon, update the relevant fields, and then press Save.
- To delete a website, click the Delete icon next to the Website name (on the right).
Caution: Deleting a website is irreversible and it will also delete any associated Matomo Tag Manager containers. When pressing the delete icon, you will be prompted to save a copy of container configurations. To proceed with deleting the website, enter your superuser password to confirm.
