Yes, the Channel Attribution report can be fetched in different formats such as JSON, XML, CSV, HTML and more, so you can integrate your measured form data anywhere. Read more about the Matomo HTTP Reporting API and view the Reporting API Reference.
Previous FAQ: Is it possible to apply segments to the Multi Channel Conversion Attribution?
