CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on two integration methods using the Matomo tracking code.
  1. Consent-based Tracking: For websites targeting users in countries that require prior consent for use of cookies and similar technologies for analytics and marketing (for example, most or EU and EEA countries), enable cookieless or cookie-based Matomo tracking only after obtaining visitor consent.
  2. Opt-out Tracking for CNIL Exemption: For organisations relying on the CNIL consent exemption for website analytics, limited tracking is permitted, provided that conditions of exemption are strictly met and users are offered a clear opt-out mechanism. CNIL exemption is strict and if any conditions of the CNIL exemption are not met, consent is also required.
Before you start
  1. Create your GetTerms account.
  2. Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
  3. Ensure your Matomo JavaScript code snippet is added to the web pages you want to track and placed before the closing head </head> tag.
  1. To install the consent manager initialisation script, copy the script from your GetTerms account in Cookie Banner > Installation.
  2. Add the CMP script to the web pages you want to track. This should be placed as the first script below the opening <head> tag.
GetTerms displays cookies using user-friendly category names in the banner (for example, Performance), but the actual consent values are stored in the cookie_preferences object in localStorage. These stored values use predefined category keys such as: Essential Cookies, Functional, Marketing, Analytics, and Unclassified.
For integrations, always use the stored consent object. For example, even if Matomo cookies appear under the Performance category in the banner, the corresponding consent signal may be stored under:
consent.cookie_preferences['Analytics'] === true
You can inspect the stored consent object in your implementation to confirm which category controls your tags:
console.log(JSON.parse(localStorage.getItem('getterms_cookie_consent')));
This ensures that tracking behaviour matches the actual consent signal used by GetTerms.
  1. If you do not have the tracking code installed yet, go to Administration matomo admin gear icon > Websites > Tracking Code and select the website you want to track.
  2. Copy the tracking code shown in the code box and paste into a text editor.
  3. Insert the line _paq.push(['requireConsent']); before _paq.push(['trackPageView']).
  4. Paste the modified tracking code before the </head> tag on all the website pages you are tracking.
  5. If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
  _paq.push(['trackPageView']);
  (function() {
    var u="//matomo/";
</script>
<!-- End Matomo Code -->
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script before the closing tag on all website pages that contain the Matomo tracking code.
(function () {
  var MAX_WAIT = 40;
  var waitCount = 0;
  function getConsentFromStorage() {
    try {
      var stored = localStorage.getItem('getterms_cookie_consent');
      return stored ? JSON.parse(stored) : {};
    } catch (e) {
      return {};
  function hasAnalyticsConsent(consent) {
    return !!(
      consent &&
      consent.cookie_preferences &&
  function deleteMatomoCookies() {
    var cookies = document.cookie.split(";");
    cookies.forEach(function (cookie) {
      var name = cookie.split("=")[0].trim();
      if (
        name.indexOf('_pk_') === 0 ||
        name === 'mtm_consent' ||
        name === 'mtm_consent_removed'
        var domains = [
          location.hostname,
          '.' + location.hostname
        domains.forEach(function (domain) {
          document.cookie = name + "=;expires=Thu, 01 Jan 1970 00:00:00 UTC;path=/;domain=" + domain + ";";
        // fallback (no domain)
        document.cookie = name + "=;expires=Thu, 01 Jan 1970 00:00:00 UTC;path=/;";
  function applyConsent(consent) {
    if (hasAnalyticsConsent(consent)) {
    } else {
      deleteMatomoCookies();
  function waitForMatomo() {
    if (typeof _paq === 'undefined') {
      if (waitCount < MAX_WAIT) {
        waitCount++;
        return setTimeout(waitForMatomo, 250);
      return;
    // Apply stored consent on initial load
    applyConsent(getConsentFromStorage());
    // Listen for GetTerms updates
    document.addEventListener('getterms-consent-updated', function (event) {
      applyConsent(event.detail || {});
  // Start after DOM is ready
  document.addEventListener('DOMContentLoaded', waitForMatomo);
Test the integration
  1. GetTerms allows you to optionally block page interaction before consent preferences are set.
  2. Open your website and use the consent manager widget to decline tracking consent.
  3. In your Matomo instance, open the Visitors > Real-time report, and check that no tracking occurred.
  4. Next, grant consent and verify that tracking started.
  5. For cookie-based tracking, open the browser’s developer tools and view Application or Storage > Cookies tab to confirm cookies were set.
  6. Revoke consent and confirm the Matomo cookies are deleted from the browser.
  1. Your website targets visitors in countries where CNIL or very similar exemption exists (e.g., France, Spain, Italy), or you have an establishment in such countries:
    • Configure your CMP to either load Matomo Analytics cookies and start tracking without prior consent, or
    • Re-categorise the Matomo cookies as Essential/Necessary.
    • The CMP banner must clearly inform users about the use of consent exempt website analytics tracking and include a visible and easily accessible opt-out mechanism (e.g. a link to your privacy policy with an opt-out checkbox).
      opt-out form matomo
  2. If your website serves a broader audience that targets visitors from countries that require prior consent for cookie based or cookieless website analytics (e.g. most of EU countries):
    • Consider splitting your banner configuration if the CMP supports region-specific geotargeting and consent rules.
  3. Follow the steps in this guide, How to include a web analytics opt-out feature on your site to add the embedded Matomo opt-out form to your website. The form includes all required JavaScript to allow users to opt-out of tracking.
  4. Alternatively, you can create a custom opt-out form using HTML and JavaScript, as explained in this developer guide.
  • Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
  • Select to opt-out of tracking.
  • Open the browser’s developer tools and view the Application or Storage > Cookies tab to verify that the mtm_consent_removed cookie is set.
  • Perform test actions on your website and view Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
  • Change the settings to opt back in and resume tracking.
  • Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
Previous FAQ: How to integrate Didomi CMP with Matomo
