There is a measurable setting that controls the number of days a crash must be absent before it is considered disappeared/reappeared.
Please follow the below steps to configure the no of days it should consider until a crash is disappeared/reappeared:
  1. Login to Matomo as Superuser.
  2. Navigate to Administration matomo admin gear icon > Websites > Manage > Edit.
  3. Scroll down to Days until a crash is considered disappeared.
  4. Add the no of days as value. E.g 20 if you want CrashAnalytics to consider a crash to disappear/appear after 20 days.
  5. Save.
Note: If you change this value, you will also need to invalidate and re-archive old reports for them to change. Learn more
Previous FAQ: How can I hide the crash context from being displayed to Matomo users?
