Yes, you can export the report and embed them via an iframe into
a different website or app
. You can also add the Multi Attribution widget to your dashboard. If you need access to the raw data, you can use the Live API or On-Premise users can directly access the raw data in their MySQL database.
Previous FAQ: Can I export Custom Reports reports and embed them somewhere else?
