If you use self-host Matomo, Heatmaps and Session Recordings are kept indefinitely.
If you use Matomo Cloud, Heatmaps and Session Recordings are kept for 3 months.
Note: Heatmaps and Session Recordings rely on raw data. If raw data deletion is enabled, older recordings and visualisations will be permanently removed. See Data Retention settings for details.
Previous FAQ: Do Heatmaps and Session Recordings support Canvas or SVG elements?
